Feature request: Right click to select extruder
wohali
Posted · Feature request: Right click to select extruder
I am very thankful for the "Select Extruder" plugin for single-nozzle prints from Dim3nsioneer.
It'd be even better if I could right click on an object in the platform and select which nozzle I'd like to print from there.
I know that I can click 2 objects that are intended to be overlaid on each other and merge them to print on a 2-nozzle setup, but for 3+ nozzles, there's no easy way to pick the nozzle that I want for each item.
Is this possible? If I understood the code better, I'd offer to write it myself, but...
    • 11 months later...
    Can someone tell me where to get the SelectExtrude plugin and how to download it? I went to GitHub and I do not see where to download the py file.
    Can someone just send me the file or post it on Ultimaker so it can be easily downloaded?
    Thanks
    Bob
    Posted (edited) · Feature request: Right click to select extruder
    Thanks
    Bob
    Well, the 'download here' on the Wiki page is not that extremely hard to find, isn't it? ;)
