Posted · Incorrect Slicing
What is going on here? There is a gap in the vertical column near where it intersects with the horizontal. The model looks good in SketchUp and in the normal preview in Cura, but the Layers view shows the gap. Printing matches the Layers view.
    Try playing around with the Fix horrible (Tape-A and Type-B) settings in Expert settings.
    However, your model is most probably incorrect. I think it contains faces on the inside.
    as a Sketchup user I cannot recommend Solid Inspector (2) highly enough.
