And please update your country in your "location" settings as advice often depends on country.
If you *do* have the ad595 solution, measure the output voltage of that board - it should be 0V for 0C and 5V for 500C and linear in between (200mv for 20C or room temp).
gr5 2,333
The UM has a AD595 tiny circuit board on the print head combined with a thermocouple. Is that what you have do you think? You should ask people in the makerbot forums (oh - right - they block this kind of post, :???: ).
Well is there a circuit board to go with the thermocouple? Or is it maybe a thermistor instead? If it's a thermistor measure the resistance at room temperature and at say around boiling temperature and then find out which thermistor in the set of thermistor tables match the part you have.
