Dim3nsioneer 556
Can you maybe put your gcode file into your dropbox and provide a link here? Please don't post the whole gcode here ...
Sure. https://www.dropbox.com/s/dgjs3jiwwfnbkcw/G-Code.ini?dl=0 is the G Code. Thanks
Uhmm... no, this is an ini file... the file generated by Cura and named *.gcode would be interesting...
Sorry. I'll try again, try https://www.dropbox.com/s/wp8j478yv5um9rz/FanMountMk3.gcode?dl=0'>https://www.dropbox.com/s/wp8j478yv5um9rz/FanMountMk3.gcode?dl=0 one. Also https://www.dropbox.com/s/wp8j478yv5um9rz/FanMountMk3.gcode?dl=0 is how the print came out. Pretty poor.
Switching between extruders seems to be 'normal', means it switches from one extruder to the other once per layer.
However, the position of the print seems to be the same for the print itself but not for the wipe&prime tower. If the offset of the second extruder is specified in Cura but not in Marlin, then the position shift should be visible in the gcode.
Daid or Tim might want to have a look into this.
I usually recommend to add the offset to Marlin (and recompile it) and set the offset in Cura to zero.
Thanks but it's only supposed to be printing in a single colour not switching. How do i set these offsets?
If you only want to use one extruder and using support you have to make sure the support setting uses the correct extruder ('support dual extrusion').
caddy-cool 0
Ultimaker? Any advice?
