Extruder Motor going crazy?
Posted · Extruder Motor going crazy?
Can anyone help me...please.
I have recently purchased my Ultimaker and although i have been fiddling, changing, swapping, tweaking and learning for what seems like weeks now and still don't have something you could really call a print..... i love it. I purchased the machine for the challenge and to learn new things - it hasn't let me down - i just wish i could print something. :cry:
My question is to do with the extruder. I have read many threads detailing the importance of getting the right amount of tension and have experienced what happens when you tighten the screw too much or too little. What i don't understand is why my extruder is spinning so much and so fast. This results in the filament being sent, smoothly to the hot end to start with and then lots of slippage and strange noises from the extruder motor there after. I have looked at as many working Ultimaker videos as i can find on YouTube and all seem to have a much slower spinning feeder wheel. Which makes sense to me..... why is mine going so fast?
The motor is very hot in comparison to the other two motors.
I have tried to print a few different files the one shown below is the 20mm box from .....
http://www.thingiverse.com/thing:5573
I have had the same extruder spinning wheel problem each time. I have also tried to print directly from an SD card on my controller.
1,
This first video shows how quickly and how much the wheel is spinning. This is at the start of the print.
2,
This one shows it stopping quickly as it is going. This just before the filament stopped coming out of the hot end.
3,
This one shows the wheel stalling and making a whining noise. I am fiddling with the wheel which shows there is no resistance.
Sorry about the toilet in the background!!!
20mm box
I am printing using Cura (mainly because this is the only program i can print from for various reasons). I am on a windows 7 machine.
These are screen shots from Cura to show settings.
These are my 'prints' so far....
Thanks to anyone who can help
    This is the start of the Gcode file - thought it might help!
    ;TYPE:CUSTOM
    M92 E86588.800000
    M109 S215.000000
    ;Sliced C:UsersBenjaminDesktop20mm-box.stl at: Wed 01 Aug 2012 13:41:42
    ;Basic settings: Layer height: 0.2 Walls: 0.8 Fill: 20
    ;Print time: 0:12
    ;Filament used: 0.34m 2.93g
    ;Filament cost: Unknown
    G21 ;metric values
    G90 ;absolute positioning
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G92 X0 Y0 Z0 E0 ;reset software position to front/left/z=0.0
    G1 Z15.0 F180
    G1 F200 E3
    ;G1 X100 Y100 F9000
    G1 F9000
    ;LAYER:0
    ;TYPE:SKIRT
    G1 X78.8 Y118.92 Z0.36 F9000.0
    G1 F300.0
    G1 E3.0
    G1 F9000.0
    G1 X119.6 Y118.92 Z0.36 F750.0 E4.9903
    G1 X119.6 Y80.28 E6.8753
    G1 X78.8 Y80.28 E8.8656
    G1 X78.8 Y118.92 E10.7506
    G1 X79.2 Y118.52 F9000.0
    G1 X119.2 Y118.52 F750.0 E12.7019
    G1 X119.2 Y80.68 E14.5478
    G1 X79.2 Y80.68 E16.4991
    G1 X79.2 Y118.52 E18.345
    G1 X83.2 Y84.76 F9000.0
    G1 X83.2 Y114.44 F750.0 E19.7929
    G1 X84.8 Y114.44 E19.871
    G1 X84.8 Y84.76 E21.3188
    G1 X86.4 Y84.76 E21.3969
    G1 X86.4 Y114.44 E22.8447
    G1 X88.0 Y114.44 E22.9228
    G1 X88.0 Y84.76 E24.3707
    G1 X89.6 Y84.76 E24.4487
    G1 X89.6 Y114.44 E25.8966
    G1 X91.2 Y114.44 E25.9746
    G1 X91.2 Y84.76 E27.4225
    G1 X92.8 Y84.76 E27.5005
    G1 X92.8 Y114.44 E28.9484
    G1 X94.4 Y114.44 E29.0265
    G1 X94.4 Y84.76 E30.4743
    G1 X96.0 Y84.76 E30.5524
    G1 X96.0 Y114.44 E32.0002
    G1 X97.6 Y114.44 E32.0783
    G1 X97.6 Y84.76 E33.5262
    G1 X99.2 Y84.76 E33.6042
    G1 X99.2 Y114.44 E35.0521
    G1 X100.8 Y114.44 E35.1301
    G1 X100.8 Y84.76 E36.578
    G1 X102.4 Y84.76 E36.6561
    G1 X102.4 Y114.44 E38.1039
    G1 X104.0 Y114.44 E38.182
    G1 X104.0 Y84.76 E39.6298
    G1 X105.6 Y84.76 E39.7079
    G1 X105.6 Y114.44 E41.1558
    G1 X107.2 Y114.44 E41.2338
    G1 X107.2 Y84.76 E42.6817
    G1 X108.8 Y84.76 E42.7597
    G1 X108.8 Y114.44 E44.2076
    G1 X110.4 Y114.44 E44.2856
    G1 X110.4 Y84.76 E45.7335
    G1 X112.0 Y84.76 E45.8116
    G1 X112.0 Y114.44 E47.2594
    G1 X113.6 Y114.44 E47.3375
    G1 X113.6 Y84.76 E48.7853
    G1 X115.2 Y84.76 E48.8634
    G1 X115.2 Y114.44 E50.3113
    G92 E0
    M92 E86588.800000
    That's not good. That should be M92 E865.888
    Check your preferences, the "Steps per E" should have a dot in it, no comma. It explains the insane extruder speed you are getting.
    There is a way you can accidentally get an incorrect value for the steps per E when using the calibration feature of Cura.
    If you run it through from the start of the wizard it goes fine the first time, but if you adjust the value and retry the 100mm, adjust and repeat, then it gets confused somehow. Or something like that. I reproduced this a number of times but as I had a workaround I didn't chase it,or report it formally in the Cura repo. Interestingly I think it kept making the number progressively smaller by half, not multiplying by 100
        • 24 replies
