Thanks! The blue print looked identical to the white until I pulled it apart. Originally I thought it drug some of the external support structure around a little so I tried the white print next without support. Before the white finished I could see inside and it looked similar to the blue. I'll try your suggestions later this weekend and report back.
gr5 2,210
The single bad layer in the white print is probably due to a tangle in your filament. Next time maybe uncoil more of the filament, or maybe put it on the floor or check that it isn't kind of in a knot by unrolling a few meters and rolling it back up.
The blue part looks underextruded inside. Try not to go over the below speeds for *.2mm* layers. For .1mm layers for example you can go twice as fast:
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
