cgb777 0 Posted March 18, 2015 in Help with cura slicing (pics) Here my model loads correctly and looks exactly as expected and how I want it to print. But once the slicing occurs, the circular concave part at the top gets covered over. Any idea why? Share this post Link to post Share on other sites
yellowshark 123 Posted March 19, 2015 in Help with cura slicing (pics) Set infill to 100% Go to Expert tab and select Expert settings... At bottom left under Infill do not check the box for Solid Infill Top. Share this post Link to post Share on other sites
yellowshark 123 Posted March 19, 2015 in Help with cura slicing (pics) Sorry it was late when I posted and my brain was not engaged. What I said may work. But it is not really the solution because I do not understand why Cura would do that. If you want to send me your STL file I will have a look. Share this post Link to post Share on other sites
xeno 99 Posted March 19, 2015 in Help with cura slicing (pics) Do you have any of the a-b combinations on ? in your case I think they should both be off (bottom right) Share this post Link to post Share on other sites
cgb777 0 Posted March 19, 2015 in Help with cura slicing (pics) Thanks for the advice, turning both a-b off results in this error though. Any other thoughts? Thanks Share this post Link to post Share on other sites
yellowshark 123 Posted March 19, 2015 in Help with cura slicing (pics) OK I loaded you .obj fie into Cura 14.07. Probably a different version to you and I got a different result, albeit wrong I then loaded the .obj file into Meshmixer and ran Inspector No idea what all those pointers are but presumable errors. I saved it as an STL file then loaded the STL into Meshlab and visually it looked fine. I displayed non-manifold edges and got 1668 non manifold edges over and 5961 faces over the non-manifold edges. As you can see they all seem to be around the top of the model. (edited to correct the picture) I then loaded the STL file into Netfabb Basic and got an error during loading I tried loading the .obj file and that loaded successfully. Doing a health check though reported that the mesh was not closed and was not orientable. In the background whilst all this was going on, I had loaded the STL file into Repetier Host; it was hung during or at the end of the intersection tests. I tried fixing the model in both Meshmixer and Netfabb but failed. Playing around with meshes is not my strong suite – hopefully someone else can help! I loaded the mesh into InStep which reported 7,545 errors including 1950 pierced facets, 4000+ unattached edges. There are 122 bodies in the mesh. I am guessing that all the bits of corn are separate bodies and where thay have all been joined together, it has not gone very well. Share this post Link to post Share on other sites
Daid 270 Posted March 20, 2015 in Help with cura slicing (pics) Cura's X-Ray view will most likely help you idenfiying the issue as well. Share this post Link to post Share on other sites
