Seems you are right about the heat. The maximun it can support it's 150C and it losses weight. At 200C it can combust.
http://www.performancepanels.com/thermal-properties
Anyone knows somewhere in europe that can CNC two small aluminium holders (exactly the half size of the umo aluminium holder) ?
mcgyvr 2
Its hot and does aid in some heat dissipation/thermal mass.
Its also fairly easy/cheap to machine and dimensionally stable/corrosion resistant, lightweight, etc...
Wood has no business being around any source of heat. Wood is a big mistake. Unless you like fires.
