Posted · I cannot set a temperature
I have had a lot of problems with my UM.
Now the problem is that it woundt heat it self up.
The UM controller shows the temperature (27c), but i cant set a temp for the nozzle.
It stands 27/000C.. I cannot set a goal for the temperature..
If I am starting a print, it stands Heating..., but it will not set a temp.
    HI oPRE,
    when you pusch the encoderwheel you can look in Prepare, scroll down to preheat PLA, this set the Temp on 180°C / Preheat ABS set to 240° C or you can go to Control and then tu Temperatur then pusch at Nozzle and Change the temp by yousing the Encoderwheel.
    I hope you understand what i say.
    I have tried that. It worked before, but not any more.
    If i set it to ex: 215c.. I can go out of the menu and to watch, but it will not sett.
    It stands only 27/000.. No matter what i try, the 000c will not change.
    O.k. you have Disasembled your hotend.
    Have you Checked out the cables ar all connected, all parts in place?
    I have checked it, but i can not find any problems there eather :/
    Can you check if the cabel from the heater ok or broken?
