Strange... Although life on my UM2 is not so great, the only problem with the extruder, I have encountered is the need to bite off the thread end cutting pliers due to the fact that it is possible to jam the threads right in front of the print head. And Yes, the printer from the shipping date is not turned off for days. Now there is a 32 hour print products, and in addition to the time spent on checking the laying of the first 10 layers, I generally don't spend my time on it. If we talk about the UM2, a stylish set of interchangeable nozzles (as usual for PLA or ABS, and a variety of exotics like Woodfill or filament with containing metal/carbon fiber) I would have bought it without hesitation.
nallath 1,113
Replacing the teflon part. I've hardly had any prints fail on the UM2 due to clogged nozzle. In most cases it's the roll of fillament that got stuck / tangled that made the print fail.
Also; cranking up the motor power can actually increase the jams, as the motor gets hotter, which means the knurled wheel also gets hotter, which causes it to deform the material more.
