Hi Ivan
You appear to have noticed something odd with your machine but it is not the same problem that I am reporting.
I would just like to be clear that the times I quoted above are what Cura estimates after slicing. Nothing to do with the machine "Time left estimate".
The actual print times are times I measured using a stop watch, again nothing to do with the machine "Time left " estimate.
ivan-lipunov 15
Hi, Peter!
I was faced with a slightly different feature, but the same kind: print time was changed in strange ways. at one point of time the printer screen showed 28 hours to complete, after 15 minutes the value was equal to 18 hours. At the end it showed 1 second until printing is finished exactly 19 minutes and 30 seconds... Also ( but it is a subjective impression) route print head is laid not in an optimal way. Because of this, in the printing process without the use of retraction on the outer edge of the object, artifacts can appear in the intersection of the route of movement of the print head
