-I forgot to mention I am printing with the Silver Ultimaker PLA that came with the machine. I haven't changed the temperature setting so that should be the default of 210. I will give 225 a try.
-I will also listen and watch for clicking. I haven't noticed anything yet, so I think this is OK.
-If I go to the Advanced Settings, they are still on the defaults so the speed settings are (in mm/s):
Infill speed: 80
Top/Bottom speed: 15
Inner Shell speed: 60
So these should all be set to 0 to so they use the same speed as the general print?
Outer Shell speed: 30
So that could be set to less than the basic print speed (so set to 10 or 15 since basic print speed is 20)?
Thank you for your help.
-Dan
valcrow 144
-What temperature are you printing at? (if default 210, try 225)
-When printing, does your extruder motor 'click'? If you watch it, it'll slowly turn (extrude) and then skip back every once in a while. This will be a tell tail sign that it's under exutrding.
-Lastly, check your speed settings in the advance menu. Make sure your infill speed is, top/bottom speed, inner shell speed is set to 0. Outer speed could be a bit slower than your basic setting speed.
Edited by GuestLink to post
