Thank you for your reply.
Lets keep this topic on your temp error, and focus on your limit switch error on this thread.
If you want help for your troubleshoot, we need some more information to get a picture of your situation.
For more general information, please read through these support pages.
Has your machine been handled rough in transport?
It could be a common denominator in this issue and your temp error.
Looking forward hearing from you,
Labern 775
Did this happen while printing?
Are you using the original fan shroud?
This can be caused by loose wires connecting the temp sensor, loose temp sensor, fan shroud with open bottom, faulty sensor.
SandervG 1,521
Like the screen suggests, you can get in touch with our technical support team.
Alternatively, you could also read through our new and improved support pages.
SandervG 1,521
Hi Kpk, did you already find help?
Let us know how you are doing, hopefully you will be back on the 3D Printing track in no-time!
Thanks,
kpk 2
Hi SandervG,
X and Y axes error has come up now how to deal with this issue
