I have had a similar problem, periodic wide layers and have just fixed it.
After a lot of playing around I realised that I had oiled the Z axis slide pillars at the same time as the X & Y rods.
The Z axis bearings are ball races, so if the pillars are lubricated the balls will try and slide rather than rotate. Some slide, some rotate and you get a jam.
I removed all trace of lubricant from the slide pillars and the machine worked perfectly and has done some over about 4 x 4 hour prints. I am routinely wiping the pillars with kleenex before a run.
John
Thanks. I think I gave the drive gear a good cleaning and a little grease. So far so good. I appreciate the help.
Labern 772
You might want to read this as it might be helpful: https://ultimaker.com/en/community/view/15514-started-to-get-some-random-yet-extreme-z-artifacts-on-one-of-my-um2s#reply-105929
Pelphry17 0
