UM2 dual extrusion <> marlin
ultiarjan
Posted · UM2 dual extrusion <> marlin
I'm trying to get dual extrusion working on my Ultimaker2
(https://ultimaker.com/en/community/view/10657-a-different-multi-extrusion-approach-um-tool-printhead-changer?page=24)
I took the UM2 marlin from github, and made the following changes;
Configuration.h > #define EXTRUDERS 2
Configuration.h > #define TEMP_SENSOR_2 20
Configuration_adv.h > #define EXTRUDERS 2
When testing a dual extrusion print from Cura (UltiGcode) the print starts, priming works, but then the Y axis stepper is starting to move extrtemely slow, and no extrusion, making me think the printer is switching the Extrudor <> Y motors ..
Any idea whats going on ?
Do I need to make more changes to the firmware ? (I see menus are not ok for dual extrusion, but thats not a big deal for now)
Also the 2th nozzle is not heating, display says 23C/-1C
From a hardware perspective everything is ok, I printed already with the 2th head from Simplify3D, and can control the temp.
    Posted (edited) · UM2 dual extrusion <> marlin
    Wild guess: A few times, I had an extremely slow moving Y axis after picking up the printhead when Cura's minimum layer time came into effect. When slicing Cura has no idea that there will be such a long distance to move after picking up the head. However, after completing this initial move the print continued as expected.
    You might check the F value in the first G0/1 command after the change sequence.
        • 4 replies
