Where can i find the log file? i'll check about the firewall, would it mean i have to allow or deny firewall access for cura?
The log file should be in the folder where you installed cura (for windows atleast).
Cura uses a local connection to connect with the slicer engine. There have been cases where firewall settings messed with that connection (which prevents slicing)
Okay, so i wasn't able to find the log file BUT i found that it indeed does have something to do with the firewall, i turned the firewall of to see what happens and guess what.. cura slices again.
Now i don't want my firewall turned of, but can't find how i can use another firewall setting for cura..
nallath 1,125
Could you post the log of Cura? Its impossible for us to say what is going wrong without it.
Also, do you happen to use a firewall?
