Print start, platform to low
coolm8
Posted · Print start, platform to low
Somehow quite funny, i have been successfully printig many hours lately and now suddenly with one part i got a problem, because the first time the V3 extruder bolt cut into the filament. After that i wanted to restart the print, and even though the print head is aligned to the platform when i home it, when the print starts it lowers the platform and moves it up again but now leaves quite a space between the hot-end and the platform.
I have been using Cura 12.07 and changed just now to 12.08. Anyway, i never had such a problem.What could that be?
    Hi CoolM8,
    Do you experience this with multiple Gcodes?
    Have you checked the Gcode?
    Look for ' Main G-code Reset extruder pos G92 E0
    ; Being_Layer_Object z=0.10
    Does it say to move the Z axis to a different coordinate?
    Have you tried re installing Firmware?
    Kind regards,
    Sander van Geelen
