Thanks for the suggestion Martin, I tried with 123D but it seems the chamfer is just a set 45 degree angle (it's also applied on an edge-by-edge basis which with a complex shape takes forever). Great suggestion though, closest I've found so far.
If anyone else has any suggestions I'd be grateful or if there are other more suitable forums I'd love to know some.
Cheers,
Dan
martin-bienz 36
Hi DannyT
I could recommend 123D Design from Autodesk. It's pretty easy to use and free software. In it's newest form, you can extrude any Text rather easy and then add a bevel / chamfer on the top. But this does not allow for simply importing images. It requires either a path (svg) or a proper font.
Also chamfering the top of complex shapes is not allways easy with 123d Design but I am sure you would get there...![;)](//content.invisioncic.com/ultimake/emoticons/5a33abe00be82_1f609copy.png)
Maybe someone else, easier process?
Martin
