I've just started using S3D on my UM2. Can't thank you enough for posting your start code. The start code for the UM2 that came with the default set up for the Ultimaker2 Extended left a lot to be desired . . .
Purchased 2 Ultimaker2 Extended at the end of last year (after a 5 day, less than satisfying experience, with an Airwolf AXIOM) to augment my 17+ years of SolidWorks design work.
Starting to get the hang of it. S3D has some excellent features, but needless to say the learning curve is a bit steeper than Cura!
Thanks again . . .
ultiarjan 1,222
Here's the start code I use for UM2 on simplify3D, but can obviously also be used in Cura when you want to use RepRap (marlin/sprinter) i.s.o. UtiGcode.
I start the priming in the front-middle due to my 2head setup, so you probalby want to change to front-left.
and the end code
Nicolinux 288
Thanks.
Yes, front left ist especially clever because the purged filament might catch on the metal clip which in turn decreases the chance it will follow the nozzle and ruin the first layer.
