Wow - over 1000 settings in there.
- 2 months later...
hey I have the same issue, I used to work with version 14 but I wanted to use the newer one,
print bed size now works but what should I change in machine head shape setting?
That depends how your head looks. The machine head shape is a polygon (points are set in sequence) where 0,0 is the main nozzle.
The head shape isn't that important, but the head shape with fans is when you're trying to print one at a time.
Daid 301
On the new Cura you want to create a json file for your custom printer.
See:
C:\Program Files (x86)\Cura_15.06.00\resources\settings
For examples. Most likely you want to base yours of the UltimakerOriginal file.
