Doesn't the 1.5.7 board also have a 12V line? I'm pretty sure it does. I think the "bottom" fan on the UMO is 12V.
No, it's all 19V. (The fan output, the pwm output and the led's output: all 19V)
My wires weren't twisted when i received my stepper motor. But it doesn't work either if i connect an other motor (which has a connector so it can't be connected wrong) to the extruder port so i think the fault is in the board or the fimware.
And the temperature of my hot end is okay. The thing is it doesn't heat automaticaly when i start a print. But if i select preheat it does work.
BTW: my firmware is the ultimaker Marlin firmware
gr5 2,330
The colors don't matter. The cables should have 4 wires twisted into to bundles of 2 wires. Each bundle corresponds to a coil inside the stepper. Wire it up the same way as one of the other motors pairs of twisted wires are. It doesn't matter which pair is which but it matters that you hook up a pair the same way as the other steppers.
Is the hot end temperature sensor reporting the correct room temperature (about 20C)? That's the hard part. Getting the heater to work is easy once you get the temperature working.
Edited by GuestLink to post
