Also make sure your nozzle exterior is relatively clean, sometimes some residual stuff on the side of the nozzle 'drags' the newly extruded material along creating thin string. I find if you have a lot caked on, set it to 90C and it peels off like a skin. (you can do a cold pull too while you're here. )
Stringing (Ultimaker Original)
Good tips....I'll try slower and if i can get the extruder to play nice under 200C
3damsterdam 0
Hello Iepaul
Stringing happens more when the temperature is higher. So try to print at 195 or 190 C and with speed 30-40.
When you bring down your speed you don't get any trouble at all.
Bert.
