I can't download Cura (404 Not found)
oesile
Posted · I can't download Cura (404 Not found)
Maybe they release today the 15.06.02 and that is the Problem, i don't know.
But you can use this link http://software.ultimaker.com/Cura_closed_beta/15.06/ if you want the 15.06
If you only need Cura there is the list with the old versions https://ultimaker.com/en/cura-software/list
Thanks for the link!
    I would stick with 15.04 for now, regardless of your OS.
    Why? The last version has errors?
    15.06.xx is basically a public beta and may or may not work depending on your hardware and printing needs. 15.04 is stable.
    It should be fixed now.
    Also; if no-one uses 15.06, it will stay in a non-stable state for a loong time ;) The latest version should already be much more stable.
    In my opinion using both versions is the best way. Use 15.06 where ist is possible, print quality is better and some really cool new features.
    And switching to 15.04 if i need to change the nozzle, because it's a really missing feature.
    You know about the work around right? Copy one of the JSON files and change it there.
    Yes i know, i have 5 Um2 in my list
    Um2 - .25
    Um2 - .35
    um2
    Um2 .6
    um2 .8
    but if i need it i switch back to 15.06 :D
    Hope there will be later the lovely textbox Nozzle Size back in the settings :D
