KevinMakes 22
On the page forums I linked you there's info about it but since you are lazy
Oh, I didn't see that there. Yes, I am very lazy too. Hahah Thanks a million. I don't think I really need it, I just wanted see what I could tweak.
For normal head it's nice to male a wipe movement or change temps, etc.
Edited by GuestOn the page forums I linked you there's info about it but since you are lazy
Example of toolchange script:
{IF NEWTOOL=0}T0 (Forces T0 so the X/Y coordinates are 0/0)
{IF NEWTOOL=0}G0 F10000 X6 ;Moves near the 0
{IF NEWTOOL=0}G28 X0 ; Home X yo be sure that the X stays align. You can remove this after you do some checks that this X/Y data fits your setup.
{IF NEWTOOL=0}G0 F10000 X6 Y50 ; Prepare to Park 1 on Left Hangar
{IF NEWTOOL=0}G0 F10000 X6 Y0 ; Park 0 on Left hangar
{IF NEWTOOL=0}G28 Y0
{IF NEWTOOL=0}G0 F10000 X176.8 Y5 ; Go Kiss Extruder 0 on Right Hangar
{IF NEWTOOL=0}G0 F10000 X176.8 Y50 ; Extruder 0 ready
{IF NEWTOOL=1}T0 (Forces T0 so the X/Y coordinates are 0/0)
{IF NEWTOOL=1}G0 F10000 X176.8 Y50 ; Prepare to park 0 on Right
{IF NEWTOOL=1}G0 F10000 X176.8 Y0 ; So long a thanks for all the fish. {IF NEWTOOL=1}G28 Y0
{IF NEWTOOL=1}G0 F10000 X6 Y5 ; Searching Extruder 1 on Left Hangar {IF NEWTOOL=1}G0 F10000 X6 Y50 ; Extruder 1 ready
{IF NEWTOOL=1}G28 X0
"So long thanks for all the fish?"
Lol, someone did notice that after 30 pages XD!!
I have change that loading-unloading sequence lately (to help with the head/park so they don't hit each other and has more margin of error) to:
G0 F8000 X5.8 Y50 ; Prepare to Park 1 on Left Hangar
G0 F8000 X5.8 Y0 ; Park 0 on Left hangar
G0 F8000 X176.8 Y7 ; Go Kiss Extruder 0 on Right Hangar
G0 F8000 X176.8 Y50 ; Extruder 0 ready
T0 ;CHANGED
G0 F8000 X177 Y50 ; Prepare to park 0 on Right
G0 F8000 X177 Y0 ; So long a thanks for all the fish.
G0 F8000 X6 Y7 ; Searching Extruder 1 on Left Hangar
G0 F8000 X6 Y50 ; Extruder 1 ready
T1 ;CHANGED
Now Y7 makes the head to avoid hitting the parked ones and does sweet no-hitting great-repeatability head changes.
Also if someone it's planning to do this, please drop me a pm so I send him the updated head/center clamp. They are much better now and it has a 0.02-0.03 error on the bearings area that has made after 2 months of use that the central head 'shakes' a bit. Tolerances...
Oh wrong post XD! I though this was the magnetic head changer post... I need some sleep
So what teh problem I am having now is that when the second extruder starts up it is printing in the wrong place... (exactly 18mm offset on the x) the exact distance between the two tool heads... so what I am assuming is that I need to have is a tool change script that says that (if tool change true go to current x(value) - 18 mm...
does the firmware have the intelligence to know current location?
Sleep is for the week lulz.
It's hard to seemon the photo being silver and the table ¿glue? But if it works clean then please share.
Yes it is silver filament, coming from the 1.6 mm head and the green (support) coming from the .4 mm there is definitely glue on the bed because I have found that even at temps in the upwards of 240C the pla has a hard time adhering to the bulidplate. the glue is hot water washable which makes it easy to remove the part when finished because simply running it under hot water will release the glue's hold.
Still refining settings, Don't want to go through with the complete build until the print quality is close to perfect. I can usually tell what settings need to be changes within the first 10 layers.
neotko 1,417
