Problem with Spliting Objekts
PropFiction
Posted · Problem with Spliting Objekts
Hey,
i try to print a Iron Man Helmet in 1:1 Size.
So if i load the helmet in Cura this size is to big.
Now i cut the helmet in Netfabb in 6 Parts.
Problem is if i load the parts now in Cura the size are way to big, bigger than the original Helmet.
Is ther any Size information in the Helmet file that i don´t see or what is wrong.
If i make 1 step forward all went 2 steps back.. arghhhh.
Hope for help
Thanky Carsten
    • 5 weeks later...
    if you look at the dimensions in netfabb before slicing the part can you validate that they make sense in mm?
    your part might be so big that Cura scaled it down when importing. I believe I've seen that before.
    STL files should be in mm. Make sure in netfabb that when you export to STL you do so in mm. If you don't you can just scale the object in Cura by clicking on it and putting in the correct scale factor. Usually you want to scale by either a factor of 10 100 1000 or 25.4 (25.4 is number of mm in an inch). Except you want it smaller so 1/10, 1/100, 1/1000 or 1/25.4.
        • 24 replies
