Dim3nsioneer 551
Guys... I'm so sorry... this is embarrassing...
It was not the pcb. It was me. Stupid. Arrgh.
The answer is in the OP.
I had my own heated bed. With an NTC. What do you need to change on the UM shield when you have a NTC? Yes, you need to add a 4.7kOhm resistor to R4.
AND YOU HAVE TO TAKE IT OUT AGAIN WHEN YOU INSTALL A HEATED BED KIT FROM ULTIMAKER!!!
(sorry for shouting)
The additional resistor reduced the analog signal at temp2 and made the firmware believe the temperature is higher due to the negative slope of the add-on pcb.
@neotko: Thanks anyway for the generous offer!
1
neotko 1,417
I have no idea but I have a pcb from the addon that I'll never will use since I bought it and I'll use the addon to make a umo+. So if you need a replacement (cost = just postal) just pm me.
