Dim3nsioneer 557
I think your point 3 is very important and might be the main reason for your issue. I recommend a replacement with an Olsson Block. Then you might consider the usage of a stainless steel nozzle for the glowfil filament. And, as @labern pointed out, make sure the bed surface is clean.
Labern 772
What did you clean the bed with? Make sure you use achohol and don't touch the glass.
Is you temp to low. If it's not hot enough it acts like a gewy rubber band and pulls off.
Check initial layer height. Make sure it's not to low or high. 0.3 is default
Check to see if you feeder is slipping.
