Posted
· Cracked wooden part on print head, replacement ?
If the main 4 holes for screw and the four big ones for the peek/cables are in the same place, it should work. But check the mm, I think that part on the v2 it's 6mm. Check the width from the broken one and the one you have to be sure.
neotko 1,417
