A common approach before the heatbed kit has been to drive a relay with the mosfet... The relay is hooked up to the heatbed and a seperate 24V power supply...
I didn't like the idea of 2 PSUs and all the relays and stuff, 19V is also generally incompatible with alot of reprap parts, and so in the end I decided to swap the board eentirely...
I now use a RUMBA board running 24V and it drives everything with a ~300W, 24V PSU mounted under the printer...
Labern 772
I know that this doesn't answer you question but It would be great to see some pictures of your hack. I'm sure others would like to see it also.
