The root cause is that the plastic shrinks as it cools, a little bit like a rubber band. This makes the edges curl up as they cool.
I must admit that I've forgotten if any real conclusion was ever made as to the best way to avoid it but IIRC thinner layers show the effect more strongly. Printing veeery slow can help as it partially re-melts the lower layers and flattens them out a bit again.
As a quick and dirty "fix" you could try enabling "Z hop when retracting" which could help. You'll find this setting in "Expert -> Open expert settings...".
There's also a plugin which can make it so that every travel move causes the bed to drop slightly and then raising up again at the end of the travel move. I don't have the link handy at the moment but I'm sure someone else will come along and post it if I don't get around to it.
It's also worth looking at the orientation of the print to see if there's any way you could minimize the problem that way.
Thank you! I tried the search function but seemed to not have searched with the correct words I indeed printed with 0.08mm thin layers. I will try printing thicker next time and if I understood correctly, use a separate fan to cool from beneath the print.
IRobertI 521
We have an old and long thread on this topic:
https://ultimaker.com/en/community/view/5094-raised-edges
Edited by GuestLink to post
Moe1992 1
