Head expanding?
fuchs
Posted · Head expanding?
I recently levelled my printing bed with a dial gauge and got it around 0.1mm even.
As the Z-Axis endstop is a little bit pesky, i set it so that i had to turn the Z-Axis by hand some clicks when the print starts.
For the first prints, i had so turn the Z-Axis around 6-8 "clicks" (to raise it) and all went fine. After a few hours (3-4), i noticed that i didn't need to turn (adjust) the Z-Axis that much, only about 2-3 "clicks". 3 hours later the machine printed without any change in Z-height and i was very happy (altough a bit suspicious).
After 3 more hours (cumulated running time around 10-12 hours) i noticed, that the start of printing did dig into the tape on the printbed and i had to _lower_ the Z-Axis :shock:
So it seems that the printing head did maybe extend, eating away the clearance between the gantry/head and the printing bed.
I checked the screws on the head - they are still as tight as usual, also the clearing at the head mechanism are all the same.
Printing works now (in the evening) when i lower the Z-Axis. Will check what happens tomorrow morning, when the machine is cooled down.
Is it possible that the whole head (heater and nozzle?) expand after long prints?
I am yet running with the v1 hotend (v2 was delivered yesterday, but i didn't install it yet, as my v1 doesn't leak atm and i currently prefer printing and experimenting to maintenance :-P )
ADD: Or is this a case of the nozzle getting looes and unscrewing itself? I am starting to find very tiny traces of burned PTFE leaking between the aluminium heater block and the nozzle...
ADD2: Ok, in the morning the clearance between head/nozzle and printing bed is as small as in the evening, meaning that either in the course of yesterday the Z-Axis has moved/the printing bed did raise ("Ascension") - which is kinda unlikely - or the head has sagged / nozzle is coming loose.
    Or maybe your z-endstop is pushed up a little bit when homing your z-axis.
    Thus after each homing, the endstop triggers a little bit later (i.e. z-platform higher).
    if you use the stock z-endstop and not a non mechanic one (like an optosensor or a hall effect sensor) and if the screws holding the endstop are not tight enough, i guess this can happen.
    Another possibility is that you z-platform itself went higher, because the screws holding it got unscrewed with the machine vibrations?
    Are you sure this is not leaking? My leaks were usually dark brown/black, I think PLA once it sits around a bit, as in a leak, burns a little.
    • 4 weeks later...
    You know if you're going to use a dial gauge to level your bed to only 0.1mm even then you may as well adjust till you just touch the head and turn the M3 screws in by 1/5th of a turn (or whatever your need your 'lift' to be) instead.
        • 56 replies
        • 29 replies
