Hi steve,
I had some experiences as you had. I think a quick fix could be like this:
1. unscrew and remove the left motor cover to expose the y-axis motor and the feeder motor;
2. unscrew the four screws of the filament feeder box to separate the feeder motor and feeder box (watch out do not let the feeder motor drop otherwise it will damage the heatbed)
3. open the feeder box it will expose the spring, bearing and the jammed filament (everything may pop out, so if you don't know how to put them back, check the UM2 assemble guide first which you can find in github/ultimaker repo or googling)
4. remove jammed material and put everything back together.
What is the diameter of your filament? The jam maybe caused by grinding of your filament if the friction between your filament and bowden tube is to much.
best,
XJ
SandervG 1,521
Hi Steve,
Thank you for your elaborated post.
Could you also upload some pictures of your feeder and Ultimaker?
This gives us a better idea of what is going on. (hint: pictures are always recommended).
Are you using the wizard to help you feed your filament?
The feeder should slowly move into the right direction while you feed the filament, and once you see the first cm come out of the feeder in the tube you can press OK and the Ultimaker will do the rest.
Can you also include a picture of the feeder's tension?
It is the white indicator/block on the side of the feeder housing.
I am sure we'll all be able to sort it out without stripping down half of the machine![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
Looking forward hearing from you!
