Your fan shroud is non-standard so you need to let Cura know this. It's very easy to do. In machine settings there are 4 numbers for distance from nozzle to each of the edges of your fan shroud. Set these up and then Cura will place your parts farther apart to avoid the fan shroud colliding with other parts.
Alternatively you can just check the check box for "all-at-once" mode which keeps moving around into different menus but in the version you have it's probably under "tools" menu.
ignatius 23
Did you try to print it with the ´quick print profile´?.
I had at the beginning some printing issues because I´ve just switched to the ´advanced print profile´ and I got lost with so many options I was not able to understand.
The ´quick print profile´ doesn´t aloud you to control every parameter of your printing, but it simplifies the process and could helps to filter some troubles.
