cloakfiend 995
Just make sure the walls aren't too thin. i do 1.2mm all over and no infill. Even complete spheres print fine like this. You only need infill if the layer is flat or begins lower than the surrounding area, but you could always hollow out the model in a 3D program and just print with supports and it will still save a lot of time and filament in the long run. Infill is usually pointless unless you are making working parts, for art stuff don't waste your time, it easy to just drill a small hole and fill it with plaster of paris to make it heavier .
here are two objects printed with no infill or support. walls 1.2mm which i think is the perfect thickness.
ignore print quality, and the gold one is just some gold leaf slapped on the model as a test, but i'm just trying to show the fact you dont need infill as much as you think. From experience, if you make the walls too thin then it wobbles when you print and the surface quality isn't as good as with thicker walls.
The smaller the model the less need for infill.
Edited by Guest-
1
cloakfiend 995
Anything with a graduated slope will generally print just fine. and the benefit of it is you usually don't need any infill with these either.
neone 40
thnx for the tip @cloakfiend, trying out that option as we speak.![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
