Labern,
Thanks of the guide load of stuff there!
Checked all the belts and pulleys but looks like is issue with the stepper motors overheating and shutting down to cool while printing, have looked that up and seems to be a common problem. Trying to see if adjusting the current to the motor works if not will try to install some fan cooling or heatsink addition.
Labern 774
Looks like you have a pulley loose.
This is called shifted layers, you can find a guide how to fix it HERE
You can navigate to the guide from the Support section on the ultimaker website.
