Buildplate temprature
Exraliser
Posted · Buildplate temprature
when starting a print my temperature is always set to 0
my chosen material on the machine itself has a set temperature for 250 but i stil have to do it by hand every time.
anyway i don't have to turn it up myself??
using the ultimaker 2
Which version of Cura? - I haven't used the bleeding-edge-new one hardly at all - letting people like you work out the bugs. For either the latest complete rewrite (14.06 or newer) or the older version (14.04 or older) the answer is probably the same - you probably selected a machine in "reprap" mode but "ultigcode" mode is preferred.
Also I recommend sticking with 14.04 for a few more months.
