Posted · Octoprint works but printing keeps failing :(
Hello,
I spent many hours with my Octoprint installation, I got it working (also on remote with a DDNS) and even the camera is working etc etc.
But prints keep failing :(
Today I tried again and today's problem was the extrusion, it was like 50% of what my nozzle is normally producing... I also noticed the "glock glock" from my filament feeder which means something was wrong :p
So I stopped the print with Octoprint, and flawlessly printed the object with my SD card and without Octoprint...
I think my start.gcode of my Cura for my UM2 is not correct, I've been reading a lot about modifications for this start code but I'm unfortunately not a programmer so it's Chinese for me that code. :D
Anyway, somebody who has some tips to get my Octoprint working?
This is the start.gcode I'm using :
;Sliced at: {day} {date} {time};Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density};Print time: {print_time};Filament used: {filament_amount}m {filament_weight}g;Filament cost: {filament_cost};M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line;M109 S{print_temperature} ;Uncomment to add your own temperature lineG21        ;metric valuesG90        ;absolute positioningM82        ;set extruder to absolute modeM107       ;start with the fan offG28 X0 Y0  ;move X/Y to min endstopsG28 Z0     ;move Z to min endstopsG1 Z15.0 F{travel_speed} ;move the platform down 15mmG92 E0                  ;zero the extruded lengthG1 F200 E3              ;extrude 3mm of feed stockG92 E0                  ;zero the extruded length againG1 F{travel_speed};Put printing message on LCD screenM117 Printing...
Any help would be appreciated!
cheers
    no, you need to use RepRap(Marlin/Sprinter)
    give this code a try
    ;*** start code ***
    G28 ; home all axes
    G1 X10 Y10 F3000 ; bring extruder to the front
    G92 E0 ; zero the extruded length
    G1 Z30 ; lower
    G1 E30 F225 ; purge nozzle with 30mm of filament
    G1 X10 Y40 F3000 ; little move to avoid dipping the plastic puddle
    G92 E0 ; zero the extruded length again
    ;*** end code ***
    G28 ; home all
    M104 S0 ; turn off heaters
    M140 S0 ; turn off bed
    M84 ; disable motors
