Well initial test show ghat this ceramic paper can hold quite good. I did trst also with a bic lighter for 3 minutes (in theory around 800-900C) and it went 'greyish' but it doesn't 'burns'. Also I could touch the paper right after and was at toom temperature (thermal camera showed a spike of 200C on a small area but banished just after the lighter was off).
It costs a full square metter around 30€ (way cheaper than nomex) but isn't exactly paper. It's a 1mm material that fells a bit like cotton and can be broken by hand if pulling strong. It cuts really nicely with scissors and kapton sticks quite ok. I'll do a pla printed part with covering the heat area and check results. One think for sure it deflects the heat better (mainly because it's a 1mm and nomex its more like a sheet of paper of 100grms).
Labern 772
don't want to blow my own trumpet but...
https://ultimaker.com/en/community/view/11554-um2-fan-shroud-replacement
https://ultimaker.com/en/community/view/11554-um2-fan-shroud-replacement?page=2#reply-115795
Note the original fan air flows at 0.6m/s and mine is 2.5m/s
Having the fans horizontal has many benefits. the fans are a lot quieter and it gives them more room for the air to flow.
I printed mine in XT-CF20, but any higher temp filament will do and recommend using Kapton tape or Nomex heat insulator/reflect paper that @neotko recommends inbetween the nozzle and shroud.
neotko 1,417
@Labern other option (nomex so far works just perfect, no discoloration 1-2mm gap between the nozzle and the paper). But I think for really really long term and wooping 1000C heat reflection, Ceramic paper. It's half the price, and there are some of them that are 1mm thickness. I waiting next week to have one to test it, since I don't know how well it will stick with kaptol or how much flexibility has. But 'on paper'
sounds cheaper/better.
Labern 772
Cool, will be Great to see how you get on with this.
