CPE
BrayChristopher
Sometimes if i'm printing really slow and hot i have fans on full but i make them full at 5mm
    Please select the answer which helped you most as 'Best Answer'. It will help future readers find the appropriate answer as fast as possible. Thank you!
    the profile should be in the new firmware.
    235 -250 deg
    65deg glass
    fans 50%
    I have tried, but couldn't find it in the settings. Isn't it released?
    It was added (at the end of the list) in firmware version 14.12 with the name "UPET" and renamed to "CPE" since V15.04.1 (i think...).
    But there's also a limit of 16 entries, nothing will change if the limit is already reached.
    Got my "problem". Cura said "no update available", but this was a problem in the Cura-Version. Got a new version and a new firmware now. Thanks.
