Actually I often lie about nozzle size going smaller (tell cura I have a .35 nozzle when in fact it is .4) but never the other direction! Not a good idea. I can elaborate if needed.
- 2 weeks later...
yellowshark 153
Your print temp is tooooo high for t-glase. I think Taulman recommend 212c. I am not at my 3D print laptop but I know I use a temp close to that. I have not changed nozzle from 0.4 although I have a diary note to try it with a .8 nozzle fitted. Oh yes I think print speed of less than 30mm/s is recommended (22/24?)
gr5 2,196
You should not increase the nozzle size in Cura unless you also change nozzles on the printer. If you have a UMO you can get a larger nozzle for well under $10 in usa (I assume 10 euros elsewhere) and if you have a UM2 you need to learn about the "olsson block" first before you can change your nozzle (google it).
What country do you live in? And which printer do you have?
