belt slips on UM1
cips
Posted · belt slips on UM1
Hello gurus.
I need an advice:
in the last few weeks I saw that my UM1 sometimes has some problems in Y-Axis movement.
This happens always in the first layer printing and more or less in the same position. The belt strarts slipping for a while.
I tried to increase the tension of the belt.
I alredy tried to align the axes (more than one time), but it looks it did not solve the problem. When I try to move the head by hand, I actually feel it a bit hard to push, especially in some specific positions. But I don't know how to fix this (more than trying to align axes).
Any suggestions?
Thanks a lot!
    Hi! I have that problem a lot, but I'm long overdue changing the belts. Here's what I do:
    * I have a belt tensioner on  the belt that slips.
    * I make sure the axis are aligned properly
    * I use machine oil on the rods... both x and y at the head and the ones along the sides where the belts are attached.
    * Before each run, I keep the printer shut off and move the head around by hand.
    Normally, I'll have problems if the UM1 sits around a week or more between runs. When I'm running ABS, because the inside temps are hotter and I'm using sewing machine oil on the rods, I find i have to lubricate them more often.
    Good luck!
