Its the nature of the design. The end of the thread gets damaged as its tightened into the element and temp sensor..
If heating doesnt work and you wont use it again then use some vice grips on the screw and a spanner on the block and wind it out. I might squeal a bit but it will come.
DidierKlein 730
Try heating up?
