can i ask you to double check the text in the endstop calibriation. it told me to check the z top endstop, i pushed it, and nothing happened, then i pushed the lower one, and that worked.
The text in Cura 12.08 is fine. But it's sometimes a bit slow to react, up to seconds. So that could have been your problem.
Not yet final, but should show some changes.
- 2 weeks later...
That does look alot better, I'd also suggest some clarity on what should be done for the steps per E test.
I made that test very clear by removing it all-together. It's not really needed to get good results, it's a 1% final tweaking thing that doesn't belong there at all.
- 1 month later...
Daid, Thanks for the quick improvements!
Best, Bill
Daid 306
I'm reworking the checkup wizard. I'm almost done with it, and it will be a LOT easier to follow, with clear indications what is happening, better logging, and pictures to show which endstops to press.
