UM2 J20 or J14 for print voltage ? UM2 V2 Board Cooling
Posted · UM2 J20 or J14 for print voltage ? UM2 V2 Board Cooling
Has anyone successfully used either of these jacks for powering a fan ( J20 or J14 ) ?
I'd like to cool the board and am printing a duct to aid in board cooling. I'd prefer to use J20 Fan 19-24V but the only reference I can find is "bad things happen" when you connect to this jack. Nothing specific though ? I know J14 and J15 are being used for laser diodes, I'd just like to run a simple fan, possibly only while the hot end is engaged.
I have both a 12V and a 24V of the same dimensions available to use.
This is what I'm attempting.
Fan orientation:
Fan duct:
Thanks.
    Ok, cracked open the cover and J14 & J15 are busy with the cooling fans and LED's..didn't remember this part when looking at schematics. So J20 is my current interest for voltage.
    • 2 years later...
    Posted (edited) · UM2 J20 or J14 for print voltage ? UM2 V2 Board Cooling
    Did you ever get this working?
    This is what i did:
    I hooked the 24v 1.5 amp blower fan to the j20 (fan 18-24v) plug.
    I printed the exact same fan duct , I hooked up the blower fan... i plug in my ultimaker and the blower fan doesn't turn on. I left it on for about 1 minute and still it never turned on. From what i read that 24v plug is supposedly always on if the utimaker is on, so why isn't it working?
    In fact it smells like it the fan may be cooked ?
    Shouldn't the blower fan turn on the second the ultimaker is turned on?
    UPDATE:
    I figured this out, the fan or the board (unsure which) had the polarity wrong. I had to splice the fan wire and connect the positive to the negative wire and visa versa , because the controller had the + and neg on opposite sides.
    I now have it up and working but man almost had a heartattack thought i roasted my board at first.
