If you have a UM2 and the extruder is skipping backwards it usually jsut means you are printing too cold or too hot but there are a dozen other causes.
Here are top recommended speeds for .2mm layers (twice as fast for .1mm layers):
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
The printer can do double these speeds but with huge difficulty and usually with a loss in part quality due to underextrusion. Different colors print best at quite different temperatures and due to imperfect temp sensors, some printers print 10C cool so use these values as an initial starting guideline and if you are still underextruding try raising the temp. But don't go over 240C with PLA.
1
SandervG 1,521
Hi Mike,
first of all, what type of Ultimaker do you have?
If you go to your account / profile you can fill out the details.
It will help troubleshooting![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
