each filament has a slightly different temp profile - worth running these 'problem' filaments at a slightly higher temp to start with, and sometimes a different flow.... then set up a profile and write on the box. Some filaments need more babying than others and I tend to use those up as soon as I can - and/or use them in a larger nozzle for 'drafts'.
Labern 773
Yes you can have bad filament, also different color may need different settings.
Is the feeder skipping or chewing the filament?
What temp are you printing at?
you could try raising the temp.
UM filament is normally pretty good but they have been having problems will silver. I have noticed that the bad silver prints better when cold. So maybe that's why your silver prints but you have problems with green?
