However, when all reassembled, even the load-new-filament process ends up with the drive gear chewing into the filament.
That's strange. That sounds like there is a huge friction in the tube itself. Is it possible you bought some 3mm filament by accident (instead of 2.9mm or 2.85mm)?
when you had the bowden disassembled did you try pushing some filament through it?
Does it grind even before the filament reaches the head? while it's still part way through the bowden tube?
gr5, thanks for your reply. The filament is marked 2.85 mm, and measures 2.8 with my calipers. With the Bowden disassembled, filament did slide easily through it's whole length, and it only grinds once the filament get to the head. so I guess that implies there is a high resistance at the head that is somehow not evident when the pushing filament into the hot end by hand (without the Bowden tube).
gr5 2,230
