Posted · How to deal with the overhangs?
problem2.thumb.jpg.9d7a770322b3ba4ad10017311fe402bc.jpg[/media][/media]
Since I had Ultimaker2, the printed stuff always has the issue of over hangs. I'm so confused how to set software to get a smooth surface? I had tried to turn down the temperature to 185, and increase the volume of fan speed to 200%.
But it seems don't work.
Here is my setting in cure.
temperature: 200-205
layer height: 0.1
print speed: 40
travel speed: 120
    set you travel speed higher. I normally set mine to 250mm/s
    30mm/s print speed will give you a really nice robot and you can print at 190. also printing 2 at once helps add extra cooling
    Posted (edited) · How to deal with the overhangs?
    If you want the best posible. Get a new fan cap (there are many for um2 to improve the symmetry of the air), print as @labern said and use blue tape with the bed off.
    And if you want to go bananas, search on this forums for crossflow fan and design an adapter for um2 :)
