Printer try to print above the body of what is already printed
ForTheFuture
Posted · Printer try to print above the body of what is already printed
Please help! My printer UM2 was printing along and then all of a sudden it raised above the printed portion on the bed and started trying to print in the air above what is already there? The print job is only about 1/3 complete. Why would the printer do this? Is this an issue with the file or with the printer?
Thanks in advance for any feed back !
Scott
    Posted (edited) · Printer try to print above the body of what is already printed
    difficult to diagnose this, were you watching it all the time ?
    if the print head gets blocked the printer does not know this and will just carry on printing, so if you missed the moment when it stopped it will just look like it s printing in the air above the print.
    I would recommend you check the feeder (at the back) and try a "atomic clean" (http://support.3dverkstan.se/article/10-the) of the print head
    check the 'layer view' in Cura to see if there is anything suspicious in that section. It is possible that parts of your design are to thin to print and Cura has to skip that section.
    If all the layers are there than you should look more into the hardware of the machine or material, like Stu said.
