Thanks ultiarjan! I'll give it a try.
DidierKlein 729
And pay attention if you increase the flow too much it can lead to underextrusion so limit the speed on the bottom layers
Thanks DidierKlien - Do you mean manually adjust the speed (whilst printing) for the bottom layers or do it in the slicer?
ultiarjan 1,223
Specially on the base layer, but also on the walls you need to overextrude, set flow to something like 120 - 140 % depending on nozzle size, also works well in "spiralize" mode.
For this print it's an easy repair, just coat the inside with PVC glue.
